Hydraulicspneumatics 5278 Promo Divelbiss Gateway
Gateway Provides IIoT Capability
Oct. 15, 2018
This M2M-enabled interface device operates as a communications gateway between virtually any type of equipment and the VersaCloud M2M Cloud.
VersaGateway is a an M2M-enabled interface device that operates as a communications gateway between virtually any type of equipment and the VersaCloud M2M Cloud. It provides communications to equipment through a variety of ports and buses, including wired Ethernet (Modbus TCP), Wi-Fi (Modbus TCP), serial ports using Modbus master-slave or custom drivers, and CAN ports (SAE J1939, NMEA 2000, OptiCAN). The VersaGateway also supports GPS allowing for mapping location. It communicates to the VersaCloud M2M Cloud via Ethernet, Cellular1, 2, or Wi-Fi2 to allow remote monitoring and controlling of equipment and to collect operational and status information for data analysis and reporting. The VersaGateway is based on the company’s PLC on a Chip, which provides powerful functionality with ease of programming.
Divelbiss Corp., (800) 245-2327
