Hydraulicspneumatics 5903 Controlair 480v Vacuum Regulator
Precision Vacuum Regulator
July 15, 2019
The Type 480V precision vacuum regulator provides precise control up to full vacuum.
The Type 480V precision vacuum regulator provides precise control up to full vacuum. Its push-type locking knob allows for smooth output adjustment and the ability to lock-in your setpoint to avoid unintentional adjustments. The regulator senses output pressure deviations to within ½-in water column pressure. Regulating range is from 0 to 30 in, Hg (100 to 1.3 kPa). It weighs less than 1 lb., and its standard bracket and integral panel nut allow for installation options. A soft valve seat design provides tight shut-off and eliminates leakage in steady-state operation. Applications include manufacturing, mass spectrometry, parts handling, and leak testing.
ControlAir Inc., (603) 886-9400, ext. 103, www.controlair.com
