The Type 480V precision vacuum regulator provides precise control up to full vacuum. Its push-type locking knob allows for smooth output adjustment and the ability to lock-in your setpoint to avoid unintentional adjustments. The regulator senses output pressure deviations to within ½-in water column pressure. Regulating range is from 0 to 30 in, Hg (−100 to −1.3 kPa). It weighs less than 1 lb., and its standard bracket and integral panel nut allow for installation options. A soft valve seat design provides tight shut-off and eliminates leakage in steady-state operation. Applications include manufacturing, mass spectrometry, parts handling, and leak testing.
ControlAir Inc., (603) 886-9400, ext. 103, www.controlair.com
