BPVA pneumatic pinch valve is designed as an alternative to traditional wetted valves by opening and closing flexible tubing to control the flow of media so it never makes contact with the valve. It requires less maintenance and reduces the risk of contamination, offers life expectancy of 3 million cycles, and features a compact design for confined spaces. With a stainless-steel, corrosion-resistant option, the BPVA is suitable for wash-down and sanitary environments. Additional options such as mounting brackets, various seal materials, and magnetic position sensing accommodate a broad range of applications. Tube slot sizes are 1/8, ¼, 3/8, ½, in. and configurations are normally closed or normally open.
Bimba, www.bimba.com
