Electronic load-position feedback is via a custom-length transducer probe sliding within a gun-drilled counterbore in the piston rod, an encased magnet and non-ferrous spacer retained in the piston by a snap ring, and a totally enclosed sensor housing with integral electronics mounted on the cylinder’s cap end.
They feature clamp diameters from 4.37 to 16.14 in. and clamp lengths from 3.55 to 11.50 in.
A protective transducer cover is optional. The non-ferrous spacer shields the magnet from any induced effects on its magnetic force and concentrates the magnetic lines of force reaching the transducer to maintain proper function. Because the electronic package is external to the cylinder envelope, it can be serviced without disturbing the tie-rod torque. Various length cord sets are offered. If mounting space is an issue, more-compact embedded LVDT-transducer technology is available.
Peninsular Cylinder Co., (586) 775-7211, www.peninsularcylinders.com
