HS-22 and HS-36 hydraulic starters use friction clutch inertia drives and can be supplied with or without gear-type motors. They come in four models, each with a different displacement:
HS-222 is 1 in.3 (16.4 cc)They are adapted from air starters and feature SAE mounting pads. Models are designed to fit both sides of multi-pad engines. They feature side and rear ports.
They are designed for the oil and gas service industry.
Pow-R-Quik, Div. of Maradyne Corp., (216) 362-0755, www.powrquik.com
