Hydraulicspneumatics 5914 Ashcroft T6500 Gauge
High-Pressure Gauges
July 24, 2019
T6500 pressure gauges are designed for measuring pressure to 60,000 psi.
T6500 pressure gauges are designed for measuring pressure to 60,000 psi. This gauge’s solid-front 304 stainless steel case meets the ingress requirements of IP66 and NEMA 4X standards. Available in either a 100 mm or 160 mm diameter, the T6500 is suitable for water jetting and water blasting applications.
Ashcroft, (203) 385-0635, www.ashcroft.com
The fastest tube line in the world
July 10, 2012
Oystar IWK has developed a machine that fills toothpaste tubes at the unprecedented rate of 750/min, making it the fastest in the world. The new TFS 80-8 uses Festo automation...
