Hydraulicspneumatics 5024 Mack Hero Cards Desktop2
Hydraulic Pump Drives—Underhood or PTO?
Aug. 8, 2018
Auxiliary power export options vehicle Classes 2 to 5 have been mainly limited to a belt-drive off the engine and under the hood. As automatic transmissions advance, many are turning to power takeoff (PTO) as a viable alternative.
Vocational vehicles are designed to handle many different tasks and come with a multitude of auxiliary equipment and support. The key question becomes, what works best for operations? Many variables need to be considered before a fleet professional can offer a recommendation or even think about starting the work truck design process. Historically, in Classes 2–5, auxiliary power export options have been mainly limited to a belt-driven provision off the engine and under the hood. As automatic transmissions advance, many are turning to power takeoff (PTO) as a viable alternative. With the addition of PTO, numerous auxiliary options have become available to the vocational truck market.
A Starting Point
Understanding your design constraints isthe most critical aspect. Begin by defining the truck’s desired functionality, operating conditions, drive/duty cycles and environmental conditions. Secondly, identify what types of auxiliary equipment are going to be powered. Determine if you require air, hydraulic, or a combination of the two. Lastly, it may be financially beneficial to plan for future demands on the truck.
Belt-driven pumps are convenient to install and replace but consume valuable under-hood space. Image courtesy of CWKits.com.
Specification writers don’t always anticipate a change in job requirements, which would be a minor cost increase at present versus a more expensive future retrofit. A common example involves dump trucks repurposed with snowplow functionality. Designing a vehicle with central hydraulics could have greatly reduced retrofit cost from the beginning. This is not always possible due to budget constraints and other unknown factors. With this knowledge and a little bit of forethought, you can determine what’s best for your operation. For either alternative, the answer can be complicated. It’s a good idea to think through the implications surrounding:
• System output (power of an underhood solution versus the PTO alternative)
• Space the solution requires of your vehicle
• Weight considerations as each add-on diminisheffective payload
• Maintainability
• Cost
Defining Demand and Controlling Costs
Everyone wants a vocational vehicle versatile enough to accomplish almost any task; however, this is not financially practical. Understanding demand can save you money in the long run. Thinking about onboard air solutions, the required pressure and volume will dictate the best type of compressor and, ultimately, how much power is required. Engine-driven compressors are typically most cost-effective for low- to mid-volume requirements—usually 20–90 cfm. Larger compressors often carry higher upfront costs as compared to PTO solutions. However, be sure to consider the big picture, including available options from OEM and aftermarket component suppliers.
When dealing with other auxiliary equipment, such as hydraulics, you can follow the same exercise. When reviewing hydraulic options for a dump bed or snowplow, depending on the duty cycle required, it may be beneficial to look at self-contained electric units that provide hydraulic operations at the point of use such as a lift cylinder. Oftentimes, this can be cost effective and simplify the truckdesign. More complex power requirements—such as a large generator or other equipment with a driveshaft—will need a PTO provision and an additional gearbox.
Avoiding Mistakes
Again, foresight is vital to getting the best solution at the most economical price. Vehicle maintainability, especially related to component locations, is key to selecting the best fit. Each additional auxiliary component could potentially influence maintainability of a work truck and the component itself. Accounting for space on board and understanding applicability of available solutions help ensure a good selection that gives you the output required to meet your needs with the right capacity balance. Items like generators, cranes, and welders may physically intrude on limited space.
A power takeoff (PTO) provides an efficient means of driving a hydraulic without consuming under-hood space. Image courtesy of Muncie Power Products.
Another common error is simply relying on what’s been done historically. Technology continues to advance; new options are constantly hitting the market. It is important to examine all advantages of new product offerings rather than assume the traditional option is, in fact, the best solution. Taking the time to analyze work environments, challenges, and actual demands positions you, as a fleet professional, to make the right choice.
Real-World Perspective
It may prove helpful to consider a practical application. For example, external power export solutions have come a long way from a stand-alone gas or drive a shaft-drivengenerator. Power management may be partially integrated into an existing truck design. A hydraulic generator is one answer; the concept is similar to the gasoline-powered stand-alone counterpart, but it’s more compact and versatile. These generators can be specified or retrofitted into existing work trucks with hydraulic circuits.
Without the gasoline power plant, size and weight can be reduced by 50%. In terms of maintenance costs, there are no gasoline engines to support and fewer environmental factors. Considering these dynamics demonstrates the importance of looking at the big picture and evaluating alternative solutions to minimize additional auxiliary equipment needs, maintenance issues, andoperating costs.
Christopher Lyon is Director of Fleet Relations at NTEA–The Association for the Work Truck Industry, Farmington Hills, Mich. Established in 1964, NTEA represents more than 2,050 companies that manufacture, distribute, install, sell and repair commercial trucks, truck bodies, truck equipment, trailers, andaccessories. Headquartered in Farmington Hills, Mich, and government relations offices in Washington, DC, and Ottawa, Ontario NTEA produces The Work Truck Show®.
Keeping Control of Hydraulic Loads
Feb. 15, 2008
Knowing the basics when it comes to emergency load lowering is critical in maintaining worker safety.
Show Yourself!
Feb. 14, 2019
If 80% of success is showing up, the spring of 2019 offers several opportunities for you to succeed. Fluid power professionals have much to gain by showing themselves before customers...
