Hydraulicspneumatics 807 Belart Red P
Indicators let you “eyeball” airflow
Sept. 11, 2013
When troubleshooting or monitoring the status of a low-pressure pneumatically powered or controlled machine — such as medical equipment or air-logic circuits — it can be next to impossible to determine if air is flowing through a particular line, even if clear tubing is being used. You could provide a flowmeter for each critical line, but that can get expensive.
When troubleshooting or monitoring the status of a low-pressure pneumatically powered or controlled machine — such as medical equipment or air-logic circuits — it can be next to impossible to determine if air is flowing through a particular line, even if clear tubing is being used. You could provide a flowmeter for each critical line, but that can get expensive. You could take the low-tech route and pinch the line, but that will only indicate a line is pressurized — you still don’t know if flow is actually occurring. Some might try loosening a line to let air leak out, but this unsafe practice holds potential dangers or could cause a machine
malfunction.
Bel-Art Products Inc., Wayne, N.  J., offers an effective and economical solution: a series of in-line indicators that clearly shows users when differential pressure (therefore, flow) exists. Mounted in any position, the transparent-polystyrene indicator contains a wheel marked with blue, red, or green triangles. Whenever there is a change of pressure in the line, the wheel spins rapidly, yielding the appearance of a solid color. Each color corresponds to the indicator size and flow rating. Blue models fit and 1/4-in. tube and indicate flows from 0.5 to 10 lpm. Red models fit 1/4 and 5/16-in. tube and indicate flows from 0.5 to 10 lpm. Green models fit 5/16 to 1/2-in. tube. All three indicate flows from 0.5 to 10 lpm and are rated for pressure to 10 psig. Whenever pressure changes at either end of the tubing n the line, the wheel spins, yielding the appearance of a solid color.
For more information, call Bel-Art Products at (800) 423-5278 or visit bit.ly/17LilVD.
