Designed for high-load/low-speed applications in nonlubricated environments, tension bushings come in standard and custom versions that provide a bearing surface between cylinder clevis pins and housings. Their full-length longitudinal slot permits compression and expansion, and chamfered ends facilitate easy installation and removal. The bushings are available in ¾ to 3½-in. ODs, in three wall thicknesses (1⁄8, 3⁄16, and ¼ in.), and lengths ranging from ½ to 3 in. Standard materials include through-hardened and tempered high-carbon spring and/or alloy steel. Metric sizes are also available.
Vogelsang Corp., (732) 364-0444
