Hydraulicspneumatics 641 Fabcoairdgpnstopcy
Pneumatic stopper cylinders
March 11, 2013
Stopper cylinders are available in seven rod-end styles with strokes of 20 and 30 mm and in 32, 40, and 50-mm bores. Shock absorbers are standard on lever/roller-style models; direction of rollers is adjustable. All styles feature magnetic pistons so magnetic sensors can be mounted on cylinder surfaces when input signals are required for controllers.
Stopper cylinders are available in seven rod-end styles with strokes of 20 and 30 mm and in 32, 40, and 50-mm bores. Shock absorbers are standard on lever/roller-style models; direction of rollers is adjustable. All styles feature magnetic pistons so magnetic sensors can be mounted on cylinder surfaces when input signals are required for controllers. Units can be double acting or single acting with spring extended rod. Double-acting models are available with a built-in fail-safe extended rod. Device’s extruded aluminum body has counterbored through holes for rigid mounting in limited space.
Fabco-Air Inc., (352) 373-3578, bit.ly/hp313fabco
