Series 319 oil-less, WOB-L piston dc pump and compressor is small and lightweight (5.1 lb/2.3 Kg). Die-cast aluminum components provide strength and durability. It provides up to 150 psi (10.4 bar) of maximum intermittent pressure, and 93% local barometer of maximum vacuum. Corrosion resistant e-coated exterior finish, stainless steel inlet valve, thermally protected motor and inlet filter/exhaust muffler all provide quiet operation. It is available with 12 and 24 Vdc motor and dryer/solenoid.
It is best suited for mobile applications including air suspension, air doors, air horns, air brakes and clutches and fuel systems. It includes EMI suppression and is RoHS compliant.
Thomas Division, a Gardner Denver Co., (920) 457-4891, www.gd-thomas.com
