The Lee Co.'s precision check valves target high-pressure, harsh-duty applications. They are constructed entirely of NACE-compliant, corrosion-resistant materials. They feature a durable MP35N poppet and seat and are designed for checked direction pressures up to 15,000 psi. The valves are available for forward and reverse-flow directions in five sizes ranging from 0.125 to 0.500 in. in diameter. Check them out at IFPE Booth S81252.
Brand Hydraulics' Series 21 direct acting solenoid operated valve features O-ring ports to eliminate leakage; enclosed solenoids and connections reduce exposure to elements, and individual load checks are built into each section. Can be combined with series 20 manual valve for increased versatility. Includes 6-gpm nominal capacity, pressure ratings of 4,000 psi (272 bar), parallel and 3,000 (204 bar), series. Ports are sized #6 SAE. Materials of this series include cast iron body, Buna N 0-rings, and stress proof tie rods. Assembly torque of 85 lb-in., 10-µm filtration, and 400 psi max tank pressure. Optional lever handles for manual control when power is lost. They will be on display at IFPE Booth S82952.
