Hydraulicspneumatics 1002 Clippard Multi Check Valves Pr P
Manifold-mounted multicheck valves
March 14, 2014
A line of manifold-mounted Multi Check Valves is designed to mount and link together with a piping system that eases assembly and plumbing. The R-614 Multi Check Valve combines four check valves into one. Features include a manifold-mounted design, integrated circuitry, and Octoport outlet design. Eight air passages extend longitudinally through the body surrounding the valve cavity integrated circuit.
The R-337 is a three-way, spring-return, fully ported piloted valve containing an independent check valve. It can be used normally open, normally closed, as a diverter, or as a selector.
The two-position, three-way, double-piloted, fully ported R-338 valve also has an independent check valve and can be used normally open, normally closed, as a two-position diverter, or as a two-way selector.
Clippard Instrument Laboratory Inc., (877) 245-6247, www.clippard.com
