Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 01 Linear Servovalve
Linear servovalve
Jan. 20, 2012
Yuken LSV(H)G linear servovalve is a fast production valve with high end response of 450 Hz (@ ±25% of full signal) up to 10 gpm, 100 Hz (@ ±25% of full signal) up to 400 gpm, 75 Hz (@ ±25% of full signal) up to 900 gpm. It is reliable with high contamination resistance, high vibration resistance and a low mechanical wear design. On-board electronics are available, as well as separate from the valve.
Yuken – Master Distributor ALA Industries Ltd.
(877) 419-8536
http://bit.ly/hp0112yuken
Handling vacuum design
Aug. 8, 2007
Material handling applications present interesting challenges for vacuum systems.
