The RTC-SB (slide bearing) double-acting rodless cylinder is oval-shaped and, in relation to its size, offers a high load capacity. This helps engineers draft more compact machine designs. Equipped with a lubrication-free slide bearing, the cylinder is maintenance-free. It resists dust and dirt thanks to a wear-free magnetically attached exterior strip, scraper, and sealing strip. This cylinder is designed for a maximum speed of 21.3 ft./sec., and the maximum stroke is 21.6 ft. Adjustable pneumatic cushioning extends its service life and ensures precise and gentle operation. Form-fit connection technology with standardized mechanical interfaces helps simplify machine design and speeds assembly.
Aventics, (859) 254-8031
