142014256 © Surasak Petchang | Dreamstime.com
Understanding how to calculate hydraulic pump and motor efficiency ratings can help determine when it may be necessary to change out the component.
How To Calculate Hydraulic Pump and Motor Efficiency
June 26, 2023
There are three ways to calculate the efficiency of hydraulic pumps and motors which can be used to determine when they need to be changed out.
In a condition-based maintenance environment, the decision to change-out a hydraulic pump or motor is usually based on either remaining bearing life or deteriorating efficiency, whichever occurs first. However, there are also certain situations where it is helpful, or even necessary, to quantify the pump or motor's actual efficiency and compare it to the component's native efficiency. And for this, understanding how to calculate hydraulic pump and motor efficiency ratings is essential.
There are three categories of efficiency used to describe hydraulic pumps (and motors)  volumetric efficiency, mechanical/hydraulic efficiency and overall efficiency.
How to Determine Hydraulic Pump Volumetric Efficiency
Volumetric efficiency of hydraulic pumps is determined by dividing the actual flow delivered by a pump at a given pressure by its theoretical flow. Theoretical flow is calculated by multiplying the pump's displacement per revolution by its driven speed. So if the pump has a displacement of 100 cc/rev and is being driven at 1,000 RPM its theoretical flow is 100 lpm.
Actual flow has to be measured using a flow meter. If when tested, the above pump had an actual flow of 90 lpm at 207 bar (3,000 PSI), we can say the pump has a volumetric efficiency of 90% at 207 bar (90 / 100 x 100 = 90%).
It is volumetric efficiency we use most in the field to determine the condition of a hydraulic pump based on its increase in internal leakage through wear or damage. But without reference to theoretical flow, the actual flow measured by the flow meter would be meaningless.
READ MORE: Digital Displacement Pump Enables Efficiency Gains
Determining a Pump's Mechanical/Hydraulic Efficiency
A pump's mechanical/hydraulic efficiency is determined by dividing the theoretical torque required to drive it by the actual torque required to drive it. A mechanical/hydraulic efficiency of 100% would mean if the pump was delivering flow at zero pressure, no force or torque would be required to drive it. Intuitively, we know this is not possible due to mechanical and fluid friction.
Like theoretical flow, theoretical drive torque can be calculated. For the above hydraulic pump, in SI units: 100 cc/rev x 207 bar / 20 x pi = 329 Nm. But like actual flow, actual drive torque must be measured. And this requires the use of a dynamometer. Not something we can, or need to, do in the field.
For the purposes of this example though, let's assume the actual drive torque was 360 Nm. Mechanical/hydraulic efficiency would be 91% (329 / 360 x 100 = 91%).
Calculating Overall Efficiency for Hydraulic Pumps
Overall efficiency for a hydraulic pump is simply the product of volumetric and mechanical/hydraulic efficiency. So continuing with the above example, the overall efficiency of the pump is 0.9 x 0.91 x 100 = 82%. Overall efficiency is used to calculate the drive power required by a pump at a given flow and pressure.
For example, let us calculate, in SI units, the required drive power for an external gear pump with an overall efficiency of 85%. And bent axis piston pump with an overall efficiency of 92%. We'll assume the output flow and pressure for both pumps is 90 lpm at 207 bar:
External gear pump: 90 x 207 / 600 x 0.85 = 36.5 kW
Bent axis piston pump: 90 x 207 / 600 x 0.92 = 33.75 kW
As you'd expect, the more efficient pump requires less drive power for the same output flow and pressure. With a little more math, we can quickly calculate the heat load of each pump:
Drive power for a (non-existent) 100% efficient pump would be: 90 x 207 / 600 x 1 = 31.05 kW
So at this flow and pressure, the heat load or power lost to heat for each pump is:
External gear pump: 36.5 - 31.05 = 5.5 kW
Bent axis piston pump: 33.75 - 31.05 = 2.7 kW
No surprise then, that a system with gear pumps and motors requires a bigger heat exchanger than an equivalent (all other things equal) system with piston pumps and motors. As this example shows, not giving efficiency its due consideration can be a mistake. And to discover six other costly mistakes you want to be sure to avoid with your hydraulic equipment, get "Six Costly Mistakes Most Hydraulics Users Make... And How You Can Avoid Them!" available for FREE download here.
READ MORE of Brendan Casey's hydraulic system design and maintenance tips
Brendan Casey Blog | Author
www.HydraulicSupermarket.com
Case drain Issues with pumps and motors: Part 2
July 14, 2010
Hydraulic motors are more sensitive to problems with the case drain than pumps are. This is because motors are usually required to reverse direction during operation.
Case Drain Issues with Pumps and Motors
Oct. 28, 2021
When modeling a hydraulic pump or motor, it is important to consider case drain flow to ensure optimized performance.
