Hydraulicspneumatics 684 Indusspec Clearvuno Tube
Pneumatic in-line filter
May 28, 2013
Clear-VU EZ Connect Filter is an in-line filter for use in most pneumatic, vacuum, and liquid applications. Push-to-connect filter features a clear plastic housing with color coded filter element to indicate micron rating. Push-in connections allow for quick replacement of the disposable filter without having to cut or replace the tubing. They are available in 6-mm and 1⁄4-in.
They are available in 6-mm and 1⁄4-in. sizes, with 10, 48, 65 or 250 μm ratings and a maximum pressure rating of 100 psi.
Industrial Specialties Mfg., (800) 781-8487,
Click here for more information.
How To Buy Hydraulic Filter Elements - The Right Way
Feb. 14, 2017
When comparing filter elements, the better filter is the one that will achieve and maintain the required or targeted fluid cleanliness level (at the lowest cost).
Filter Elements in Hydraulic Filtration: The Key to Efficient Hydraulics
June 22, 2022
Selecting the right filter for an application will ensure proper performance and efficiency of hydraulic systems.
